CSV export
stokemusic
When exporting the music library as a CSV file, would it be possible to also export the tags list? or even better to be able to tick which columns to export.
We'll add the Tags column to the exported CSV file, thank you for the suggestion.
That would be great but we are now on version 6.0.2.0 and the tag column still doesn't appear in the CSV export. Will it be implemented in this beta version? Thank you.
It's not yet available but it's planned to be included in one of the next updates.
