Delete & Disable Event Column in Scheduler
radioena
Would it be possible to consider adding the Delete and Disable Event date/time column in the scheduler. We can view at a glance if the delete/disable event has been added and the date/time it will be actioned.
Thank you for the suggestion, we'll consider adding this column in the future versions.
