If I manually drag an mp3 in to the playlist is there a way to tell it to delete after it plays?
NEPhillyRadio Member Nov 10, 2021 #1 If I manually drag an mp3 in to the playlist is there a way to tell it to delete after it plays?
D djsoft Well-known member Staff member Nov 11, 2021 #3 You can use the getfile command, it has an option to delete the files after playback: https://manual.djsoft.net/radioboss/en/scheduler_commands.htm (this command can also be added from the scheduler wizard).
