Display Song
  • Thread starter Thread starter megastacja
  • Start date Start date
M
megastacja
Guest
Hello if there possible to display song what are now playing on the status bar of this software , or mabe it possible to do it to save to the txt , but only file name "Feel-Jest_juz_ciemno" without
<?xml version="1.0" encoding="utf-8"?>
<PLAYER name="RadioBOSS" version="2.8.5.290">
<TRACK ARTIST="" TITLE="" ALBUM="" YEAR="" GENRE="" COMMENT="" FILENAME="D:\MUZYKA\Feel-Jest_juz_ciemno.mp3" />
</PLAYER>
Or mabe you know some software , where i can convert on the real time file of xml where i can get only information about file name and then save to the txt
In the new version, there will be an option where you can select the format (text/xml) which is used to write file.
