Hi Dmitry,
due to technical reasons I have to play an add-trigger every now and then. I send my metadata direct to TuneIn with settings like PartnerKey, ID, etc. in this field:
checkbox "current title" is of course activated
But problem then is, that this add-trigger-metadata also appears on TuneIn
Is it possible for you to build something that this specific titles (with always the same name) are somehow filtered and will NOT be send to TuneIn? So I can say; please send all current titles except the ones with the name "add-trigger" f.e.
That would be a great new feature.
(It doesn't help to just set a category with the add-trigger-track which has the setting that the title should not be shown - because I have to send the add-trigger as it is so that the server from another service recognizes it's time for adds. I am just talking about the things that are send with "GET" to TuneIn.)
