ERRO DE LIGAR AO SERVIDOR
Beto Tuga
TOCA DUAS OU TRES MUSICAS E DESLIGA-SE DO SERVIDOR-
TENHO UM SERVIDOR sonic COM HTTPS
Error message 40 means there is a problem with the network, you shuold check your internet connection (if it's stable and fast enough) and also check the server you broadcast to, may be it has some problems. RadioBOSS can't do anything about it, it only shows that there is a problem with network, it does not cause it.
tenho uma internet bastante boa,
600 Mbps
Fibra óptica
nunca tive problemas com a internet.
Obrigado pela informação que me deram
In this case it can be something to do with the server. RadioBOSS only states the fact that there is a problem, it does not cause it, nor it can do anything to fix it.
