Error log printout
Conway
I was looking for a way to print out my 'error log' from the front panel to read over the errors and events. Is there currently a way to do this or could it be added in next update? Thanks!
You can find the raw reports in the reports folder - click Settings->Open reports folder, those are .csv files, you can print them using any software that supports .csv files.
