Error with Stereo Tool
z100internet
Hey Dj Soft -
The latest version of RadioBoss is crashing with the Stereo Tool Winamp Plugin. I have Downloaded several different versions of Stereo Tool, but they all seem to crash RadioBoss after running about 2 hours or so. When I run RadioBoss with no Winamp Plugin, the software runs fine and is free of errors.
This is strange. I have the newest version of RadioBoss and I am using the newest StereoTool tool and it works fine for me. How much RAM does your computer have and are running other applications will RadioBoss is running?
I have 1.75GB available on the system, and RadioBoss is the only program open and running on the system at all times. But like I said, RadioBoss runs fine with no Winamp plugin, and crashes 2-3 hours after Stereo Tool is activated and turned on. I saw another post about Radio Logger crashing in the same time window (every 2-3 hours) and was wondering if these problems could be related?
Can you try it on another sound card?
Also I think it depends on what settings for StereoTool you're using, you can try loading standard preset and see if it solves the problem...
