Event Feature Inside "Run Now"
djwolf
When I have an hourly event at 00:00 past the hour to place a track in the playlist and Say right now it is 10:45:00 and I click on Run Now, I would like to have it to where when I click run now It will run at 10:45:00 but won't run at 11:00:00 and then after that it resumes on normal schedule. Any Comments?
You can open event properties and disable event temporarily: uncheck the "Enabled event" option.
I'm afraid there's no way to skip event launch automatically...
I thought about your idea. I think the feature "skip next event launch" will be added for the "Run Now" button in the future versions.
Thanks.
