First approach with Radioboss.fm
liga
Hello everyone,
I finally started my own radio station with your radioboss.fm. I'm really happy. I'm still studying, but I would like to ask you for some info.
Is it possible to have the director communicate with a Bot to interact in an IRC chat? Do you know a radiobot that can be used for IRC chat? Is it possible to make listeners search and request (auto)playing of songs? finally, if I have to pass the radio statistics (listeners) to an (already existing) bot, what is the link on the information page? I have many more questions but I'll ask them later. thanks in advance and best regards
liga
RadioFebbre - www.lafebbre.ch
I can't help you with IRC bots, sorry. Song request feature will be added in one of the next updates.
Internally it uses Icecast server, you can gather statistics from it using Icecast API (there are ready scripts on the net that allow doing it).
thnx dj soft, I'm very happy about your radioboss cloud.
for irc bot scripts, I can't find any. Is it possible to have a listener request manager in radiobosscloud? A kind of jukebox. Thanks again!!!!
liga
ah sorry, another question.
In the configuration of an IRC bot that can receive information from Icecast, I have to set this field:"URL statistics icecast". Which link from radiobossCloud should I give? Sorry and thanks again
liga
Song request widget will be added in one of the next updates.
I think you should ask bot's author about it. The base Icecast server URL is in Server Page area, probably it's the one that's needed.
hi djsoft,
nothing... like that doesn't work. I don't understand what this status-json.xsl file is. Is it a standard protocol that Icecast (radioboss.fm) provides without logging in as admin? Obviously I put the port number of MY servers, but it still doesn't work. I really can't understand. Thanks again and sorry for these questions.
bye bye
liga
Hi, I tried this with my wordpress plugin player and it doesn't work.
It's looking for Icecast2 though.
"Icecast2 Status Page URL : If this is an Icecast2 live streaming, you can enter the Icecast2 status page URL to get the live song title."
Is there a way to make this work?
I would like a nicer looking Currently playing and Up Next. It doesn't look very good on my page. ktamradio.com
Thank You
You can find Icecast server URL in the Information section. RadioBOSS Cloud uses Icecast 2 so your plugin should work with it.
Widgets that are offered in the Integrations section can be fully customized using CSS rules. For example, the widget that shows the currently playing song has a class rbcloud_nowplaying so you can style it as needed with css e.g.,
CSS:
.rbcloud_nowplaying {
    font-size: 1.5em;
    font-color: red;
You can see all this in the widget's code.
It's better to use the widget and customize its look that pull data from Icecast. Widget will show a correct title in some special cases like when live streaming is enabled.
I don't know how to use CSS.
This is what the plugin is asking for, in the image, but the information isn't being displayed on the player.
