Functionality questions: Adding song art, sharing playlists, analytics
airrromanaradio
Hi there, everyone!
I am evaluating the platform coming from SAM Cloud and RadioJar, and would appreciate your guidance about the following questions, or pointing me to your help files if available:
a. Let's say I want to run two stations using the platform, is there an option to share playlists under the same master account to avoid uploading in both stations?
b. Do the analytics provide info about what the referrers the listeners are listening from and their location, or only if the listener listens from the Radioboss.fm stream?
c. When I upload a song or a media file (one time): a. Can it be included in different playlists and still be counted as one song/file without affecting the space of my account? Or do I need to upload it several times and every instance of it would count toward the space of my account?
b. Can you please point me out where to find info about the album / song art is added? Does the platform allows searching online (Google, etc) and harvesting the metadata into the song fields instead of being typed manually?
Thank you for clarifying and for your insight!
A.J. - airromanaradio
In RadioBOSS Cloud, all accounts are separate entities. This allows you not to worry when deleting files, you don't need to think if a file can be used by some other radio. We offer plenty of storage so keeping copies of the files shouldn't be the issue.
Currently it doesn't show where listeners come from.
Inside one account, a file can be used multiple times in different playlists, or played directly without being in the playlist.
It reads metadata and cover art from the tags.
