Hardware Required?
HMMMM
Could you please let me know whether anyone is currently running a live phone-in show using RadioBOSS?
I would be interested to know what additional hardware and software would be required to allow listeners to telephone into a live broadcast, alongside my existing audio mixer and RadioBOSS setup.
In particular, I would appreciate any recommendations or examples of working setups that would allow callers to be heard on air while maintaining control of their audio through the existing mixer.
Many thanks for your advice.
AI Said
How it works — core concept​
Your existing mixer is the key piece here. You don't need to change how RadioBOSS plays your scheduled audio — you simply add the caller's audio as one more input channel on your mixer, exactly like your microphone or CD player. You control their volume, on/off, and EQ from the mixer just like any other source.
Caller → Phone Interface → Mixer (spare channel) → Main Mix → RadioBOSS (or encoder) → Broadcast
Studio Output → Mix Minus → Phone Interface → Caller hears you
The critical detail is mix-minus — you send everything except the caller's own voice back to them, so they don't hear an echo.
Option 1: Software-based (Low–Medium Cost)​
Best for internet/cloud calling; works with Skype, Google Meet, Telegram, SIP.
Software needed​
  • Voicemeeter Banana (free virtual mixer) or Virtual Audio Cable – routes audio between apps and RadioBOSS
  • Calling app: Skype, Google Meet, Telegram, or a SIP client
  • RadioBOSS — use its MIC/Line Input section to bring the caller feed into the broadcast
How to connect​
  1. Caller audio from app → virtual cable → Voicemeeter → spare input channel on your mixer
  2. Your main mix (minus caller) → virtual output → send back to the calling app
  3. RadioBOSS continues playing your scheduled audio as normal; its output goes to the mixer
  4. When you press MIC On in RadioBOSS (or route the mixer output to your encoder), the caller is heard live
Pros & Cons​
  • ✅ Low cost (Voicemeeter is free)
  • ✅ No extra hardware beyond your computer
  • ❌ Relies on internet stability; PSTN-style landline quality not available
  • ❌ Managing mix-minus virtually takes careful setup
Option 2: Hardware Phone Patch / Hybrid (Professional Quality)​
Best for real telephone lines (PSTN) or SIP with broadcast-grade audio. These units handle the line, echo cancellation, and mix-minus automatically.
Recommended hardware​
Table
ProductTypeNotes
JK Audio Innkeeper / ComPatchAnalog hybridConnects standard phone line to mixer; built-in echo cancel; balanced XLR I/O
JK Audio RemoteMixPortable hybridGood for single lines; works with mobiles via adapter
Telos VX / ZephyrVoIP/SIP systemMulti-line broadcast phone system; AES67/AoIP options; professional studio standard
Studio Technologies Phone InterfaceDigital/SIPClean digital I/O; great for modern setups
Broadcast console with built-in phoneAll-in-onee.g., Axel Oxygen has integrated telephone hybrid
Connection diagram​
PSTN/SIP line → Phone Hybrid Unit → Audio Out → Mixer Channel N (fader controls caller level)
Mixer Aux/Send (Mix-Minus) → Phone Hybrid → Line In → back to caller
RadioBOSS output → Mixer Channels 1–2 → Main Mix → Encoder/Broadcast
Your Mic → Mixer → Main Mix → Broadcast
Pros & Cons​
  • ✅ Broadcast-grade audio; dedicated echo cancellation
  • ✅ Simple fader control from your existing mixer
  • ✅ Works with standard phone numbers
  • ❌ Hardware cost (£300–£2,000+ depending on lines)
Option 3: Hybrid — Software + Simple Hardware​
If you want phone-in capability without full broadcast gear:
  • Smartphone → Bluetooth/USB interface to mixer (e.g., RØDECaster approach works with any mixer with a spare channel)
  • SIP softphone on PC → USB audio device → mixer channel
  • Use RadioBOSS's MIC input or feed your whole mixer output to RadioBOSS's encoder
Proven Setups — Examples​
Example A: Community Station (Software-Focused)​
  • PC running RadioBOSS + Voicemeeter Banana
  • Skype receives listener calls; audio routed via virtual cables to Voicemeeter
  • Caller audio → Voicemeeter → USB interface → Mixer Channel 3
  • RadioBOSS output → Mixer 1–2; Mic → Channel 1
  • Mixer output → RadioBOSS MIC input → to stream
  • Mix-minus set up in Voicemeeter so caller hears program without echo
Example B: Semi-Pro Station (Hardware Hybrid)​
  • JK Audio ComPatch connected to a standard BT/Openreach line
  • ComPatch output → balanced XLR to Mixer Channel 4
  • Mixer Aux Send (program minus caller) → ComPatch input
  • RadioBOSS plays scheduled music → Mixer 1–2
  • Host mic → Channel 1; Caller → Channel 4
  • Mixer main out feeds your stream encoder — RadioBOSS runs as normal plus the live mix passes through
Example C: VoIP/SIP Professional​
  • Telos VX SIP phone system registered to station's SIP trunk
  • VX audio over network → Dante/AES67 interface → mixer
  • Each call appears on its own fader
  • RadioBOSS handles automation; mixer handles all live elements
Key Tips & Best Practices​
  1. Mix-minus is non-negotiable — if you send the full main mix back to the caller, they'll hear themselves delayed (echo). Use an auxiliary send on your mixer that excludes the caller's channel.
  2. Keep RadioBOSS independent — let it continue playing your playlist; treat the caller just like another live source. You can even use RadioBOSS's Voice FX or MIC button to "duck" music automatically when the line is live.
  3. Latency matters — keep buffer sizes low in your audio driver (10–30ms range) so conversation feels natural.
  4. Test without broadcast first — have a friend call in while you monitor locally; fix echo/latency before going live.
  5. Recording — consider recording the full mix separately if you want to archive shows.
Summary​
  • Is it done? Yes — many stations use RadioBOSS with live phone-ins daily.
  • Cheapest path: Voicemeeter Banana + Skype/SIP + your existing mixer → free–low cost.
  • Best quality path: JK Audio or Telos hybrid + your mixer → broadcast-grade, reliable, proper phone lines.
  • RadioBOSS role: stays exactly as your playout system; the mixer integrates everything together.
Would you like me to help you work out the exact cabling and audio routing for your specific mixer model and computer setup?
