Help Weather
nikiford
Hello , I am impractical and even help can not figure out how to activate the commands of the weather if it is in a single line type "weather roma, it ; tts (0) = ?Temp"
or as I do to hear from tts because if I write only " ?temp" I pronounce as it is written without giving me the temperature , for sure I'm doing something wrong but the help does not help me because there is not a complete example
thanks for any help.  ??? ??? ??? ???
You need to run the "weather ..." event some time before than the actual announcement. E.g. run it on 00:00:00 and then announcement at least one minute later (to ensure that weather data is downloaded and processed). Please check the Log window (botton left corner) if there are any error messages when you run the weather command.
ok thanks now check
but what I wanted to understand the command to give is so? to ensure that the active tts or any mp3?
or example:
entering a multi-line
that is
weather roma,it
D:\Documenti\Weather\Temp\TMP?tmp.mp3
As I said in the previous message, you need to have 2 separate events, one that runs the "weather roma, it" command, and another event (at least a minute later) that plays the announcement. Do not use one event to perform both actions.
OK thanks ;)
the second event in the mp3 command as well as in the picture or do I add something?
unfortunately I give me this error I have the 5.3.3.1 version
17:00:01;scheduler;"Command ""weather Roma,it""";
17:00:01;scheduler;"Weather data updated.";
17:01:00;scheduler;"Schedule: TMP?tmp";D:\Documenti\Weather\Temp\TMP?tmp.mp3
17:01:00;;TMP?tmp;D:\Documenti\Weather\Temp\TMP?tmp.mp3;"<TRACK LISTENERS=""0"" IDENT="""" ARTIST="""" TITLE="""" ALBUM="""" YEAR="""" GENRE="""" COMMENT="""" FILENAME=""D:\Documenti\Weather\Temp\TMP?tmp.mp3"" DURATION=""??:??""  PLAYCOUNT=""1"" INTRO=""0.00"" />"
17:01:00;error;"Unable to play! Error code 2 (unable to open the file/invalid server address).";
maybe I'm doing something wrong
Please update to the latest version, there were some issues with weather announcements in 5.3 and prior versions and those issues were addressed in 5.4.1.
