it's possible
It is already possible, you can use the hot key to enable and disable track repeat - the R key (by default, can be changed in the settings).
DJ Denise
Hi, Is it possible to make the scheduler schedule and play a  wave or jingle that you have set up every interval please?
DJ Denise
Is it also possible on shuffle to add a pick a genre in a pop up box or settings so it only picks songs of tempo range or genre thanks for looking D
DJ Denise
when you thinking of adding are scheduling a wave track would it be possible to do this in shuffle and only play the announcement in the gap between tracks 6s or less each side or in middle ?
You can use the "Repeat every" feature: https://manual.djsoft.net/radioboss/en/scheduler_options.htm
If you need advanced track filtering and selection options, please use the playlist generator: https://manual.djsoft.net/radioboss/en/using_playlist_generator_pro.htm
