Do you mean the events still run when you have this option on?Yes I have it set. Doesn't work!
This is a separate option, it's not about the scheduled events, it's about starting the next track after you turn off the MIC.The reason is to block this function when Play next track after MIC is turned off is checked next to the microphone button.
Yes. player continues to play the songs and the system loads the scheduled commercials and jingles.Do you mean the events still run when you have this option on?
This option doesn't prevent playing tracks in the playlist. Scheduled events will be loaded, but playback will not start. However, if playlist was already playing, they will play. This option does not stop playback.Yes. player continues to play the songs and the system loads the scheduled commercials and jingles.
Ok. How can I stop a playlist?This option doesn't prevent playing tracks in the playlist. Scheduled events will be loaded, but playback will not start. However, if playlist was already playing, they will play. This option does not stop playback.
You can press "Pause" button, also in Settings->Inputs you can configure music level when the microphone is on, if set to a very low values, music will not be heard.Ok. How can I stop a playlist?
YES. I am using the program version 6.2.4.2 Can you check if this problem occurs. This is cumbersome because ads play, jingles, and everything that is scheduled for a given time. Unless a different schedule must be set.Do you mean the events still run when you have this option on?
Thank you for the details, we'll check if there's bug.YES. I am using the program version 6.2.4.2 Can you check if this problem occurs. This is cumbersome because ads play, jingles, and everything that is scheduled for a given time. Unless a different schedule must be set.
