Microphone is blocking
patrick.de-bruyn
When using the microphone button, it sometimes blocks and the microphone stays on no matter what you do.
The only thing that helps is to change the push to talk status in the settings, briefly press the microphone and reset the push to talk in the settings.
this happens with different users on different computers
i think this is a bug
Please specify what RadioBOSS version is used, and what device/driver is selected for the MIC.
How often does it happen, and how long does the lock last?
In my case, the microphone freezes for a second or two, and then Fades Out, abruptly. FadeIn is much smoother. That's how FadeOut should be done.
The lock lasts until you change the push to talk status in the settings
I don't think it's related to the PTT option, it's just that MIC can be restarted because of settings change.
We'll make some improvements/fixes in the next update about it.
Does it happen each time you use the mic or only occasionally?
A few clarifications:
1. The entire interface freezes for 1-2 seconds (one second in most cases).
2. Every time.
