Microphone PTT
patrick.de-bruyn
Some users have the following problem: when using push to talk, sometimes the button is blocked and you have to switch off push to talk in the settings,
then go back and switch off the microphone by clicking the button twice
then go back to the settings and turn push to talk back on
this behavior does not always happen, i personally had it only 2 times with version 6.x
others also reported it with version5.x, one with version 6.0.1.8
Some of them use Win 11, i use Win 10
When the button is blocked, what actually happens with it? It's no longer possible to press it?
the microfone is activated and it is nor possible deactivating it
after that its ok again
