Mirroring settings on another PC
Gtjhgftgf
Good day. The question is in the title. Is it possible to configure RadioBoss so that the settings, current playlist, and history of played tracks are the same on two computers? For example, on computer A, the order of tracks in the list, history, and scheduler are set up and, at a specified interval, they are transferred to computer B. And vice versa, from B to A.
This wouldn't be really possible if you run the two instances simultaneously. Two programs will write to the same settings folder and this will cause a lot of conflicts and/or corrupted data. Transferring of the settings is possible using the Backup/Restore feature - it's located in the settings menu.
