Multiple scheduler actions
ormston
seems to be some problems with running multiple events that combined commands, they don't seem to work as predicted, i might just go back to having them as separate events. I was trying to combine the various command to disable and enable groups to switch between different "modes" that i like to run, but i am finding that they dont seem to run correctly, whereas when they are separate events separated by a minute or so they work correctly.
When you say it's not work as expected, what does it do, can you please provide some details?
