So I use Music Master as my scheduler. Can I insert a playlist manually into RadioBoss? If so, are there settings I would need for Music Master to grab the audio?
Thanks for the reply. Now, i have done exactly as you suggested and when I bring up the playlist, it runs, but skipping every song. I have the "Unable to play! Error code 2 (unable to open the file/invalid server address)." Can you help?
can RadioBoss receive logs from third party schedulers please have them provide you with a sample exported log of how their system would prefer to receive the flat file so we can create the export design for you with the proper columns and rows for all your fields to be imported correctly into their system as a delimited or fixed flat file.
