No event if RadioBoss does not stream
jeiben
certain events can be stopped by the "Do not execute event when playlist is paused" option.
However, if I create my playlist while only listening to music in RadioBoss, the event will be executed, which is not desired in that case.
Is it not possible to add an option "Do not run event when RadioBoss is not on air"?
kind reagards
You can disable the scheduler when you don't need it. Or even automate it - use the two commands:
disconnect
scheduler off
This will make it disconnect from streaming servers and also disable the scheduler.
