"Now Playing" Feature For OBS?
mcurran
Hello
I'm thinking about running an online radio station through OBS into Mixcloud with RadioBOSS as the automation player. Does RadioBOSS have an output option that will show "Now Playing" that gives Artist and Song Info to display as a source I can select on OBS?
RadioBOSS saves the "nowplaying.txt" file with the current track information, probably you can use it with OBS:
mcurran
Okay I will check it out. PS: If anyone here is currently using RadioBOSS with OBS in this capacity, please advise.
thank you much!
