Pause required between each song
You can insert a timed silence action into the playlist by selecting:
Playlist -> Add timed pause... -> (Enter duration desired) -> OK
Per your post, you would enter 20 as the duration desired.
The "Set broadcast title" is what your listeners would see during the silence duration.
Make an Event as in the Picture below so you only have to rightklick and do run now
