Playback/next track issues
Riddle
I still have some issues with our Radioboss although we keep updating and are on the new version.
Also tried 'clear tag cache' a lot, but it doesn't help.
Two main issues:
- When I manually advance to another track, the current track does not fade, but stops abruptly and it starts the track I started, before the current track would fade out (ish). When I use the segue editor for tracks and I play the tracks in the segue editor, the track stops literally at the 'start of the fadeout', see: https://i.gyazo.com/69f3d74c3ed8b6471a1d010727ce77ec.png
- Sometimes the Segue editor shows a downward line in the 3 tracks in the editor
The second issue is less problematic than the first one, I just don't save it and open the segue editor again and then it would be ok
Cross fade settings: https://i.gyazo.com/833e0e503f3f7a91dfbeda5e1711a4c3.png
I have the Mix Point set at 0 seconds. If the song was recorded with a quick ending it waits for the track to end and starts the next track. I have Trigger mix set at -15 db for songs that fade out. I have Fade out set to 3 seconds with Start fading out on mix. This work well for me.
Please also check the special next track and stop fading settings: https://manual.djsoft.net/radioboss/en/fading.htm
Riddle
See screenshot: https://i.gyazo.com/e4a2cfc405402da60cf7c2cf5facc956.png
Looks good to me
Also see the video of what's happening: https://streamable.com/0jqwuz
- At the end of the track Halo, it just stops abruptly and plays the sweeper
- After the sweeper, it fades out well because this is setup in the track editor
- I manually advance to Nelly Furtado and it abruptly stops Bad Bunny
In this case it should use the "Fade out on stop" option. I did a quick test and this option is correctly applied. Do you use the latest RadioBOSS 6.1.1? The screenshot link you've sent did not open so I was unable to see the settings and version.
