Player code to open in its own window
markyburns
Hi, is there a code available so that the player opens in it's own window?
I have embedded the current code into website, when you listen live it works great, but whilst listening if you look at any other page on the website the player will stop.
Any solutions or suggestions greatly appreciated.
cheers
It's not about the player itself. You can create a separate window that will host the player. Or rework your web site to use AJAX so the player won't stop when you navigate the web site. You can see it in RadioBOSS Cloud control panel: you can start playback with the player (in the top right corner) and freely navigate the control panel, and it will continue playing.
markyburns
Thank you so much for replying, it doesn't sound impossible which is great...... I just need to explain it to the guy overseas that built the website :-(
Your webmaster should handle this task. It can be a bit harder with Wordpress, but not impossible.
