Playlist Generator Pro crash
David
When running RadioBoss and going into Playlist Generator Pro sometimes causes RadioBoss to shutdown and then Generator Pro shutsdown.  Have tried to increase time from 25 sec to 2 min with the same results.  I have to restart the computer then notice that RadioBOSS beta 4.7 has to be reactivated each time.  Thanks for any help.
David
This will be fixed in the RadioBOSS 4.7.2 update - playlist generation will be performed in the background and radioboss won't freeze, lock up or restart.
Regarding the beta version, if you use it too much, the program will reset the activation. Does your code still work?
Thanks for fixing this.  Yes my beta 4.7 code still works at this time.  Thanks so much for all your help....
David
