playrequestedsong ignored again
Riddle
Hi,
Just like in this topic: https://www.djsoft.net/smf/index.php/topic,5005.15.html
The "playrequestedsong" command is not working. There ?re requests in the 'Song Requests' window, however when the playrequestedsong command is in the playlist, Radioboss just skips it and removed the request.
Anything changed here? Version 5.7.2
Can you please provide more information, what command do you use - is it inserted from a scheduled event (if so, is it a single action or a part of multi-action event), or it's inserted using other means? How long is the requested delay?
Riddle
Manually added and with the playlist generator (where "playrequestedsong" is in a category and put in the rotation)
Manually add:
Playlist -> Add command -> playrequestedsong
Just like we used it last year with the season stations. In fact nothing had changed on the playlists like we left it ;-) And tried to setup a new playlist, same reaction.
Riddle
Thank you for the information - if the bug is confirmed, we'll fix it in the next RadioBOSS 5.8 update (you can subscribe to RadioBOSS 5.8 topic to monitor the changes): https://www.djsoft.net/smf/index.php/topic,5601.0.html
