villanosuy
Dimitry:
I have a list generated with the PL genreratore with this form: presentation of the show, 1 hours of musical format from one folder in aleatory mode and the closed jingle of the show, all its ok when i made the PL and save it when i push the generate button and then save with a show name, and then I schedule it to play all the day at the same hour
The generate list its showed as 1h02 min long when generated, but when start to play on each day the duration varies from 56 m to an hour and a few minutes more, there is no problem.. but almost every day the generated list is around 56 up to 58 min an in rarely case has 1 h and one or two minutes more, then the shows ends in less than a hour and several times/days I have up to 4 minutes of silence, until the next shows start automatically when programmed.
How I can fix these errors, in the words how I can ensure that playlist have an hour of minumum time for each day automated generated playlist??
thanks in advance for your help!!
