Problem with spliting records
RDJ
We are using Radio Logger 2.5.0.1 and everything was fine, records was 1 hour long, but in last two days everything is recorded in just one file. We checked settings and everything is set as it should be. Any solutions?
You can try updating to the latest version to see if it fixes the problem. Please note when you start the recording manually, it will not be split into parts and will be recorded as a single file. Only scheduled automated recordings are split.
