Problems with HLS file (m3u8)
Hi,
In one of the latest updates of RadioBoss, you bring the option to play m3u8 playlists (hls), with the new support to this tipe of files.
I tried today, and at first it worked ok, but then it says to me that error:
Unable to play! Error code 17 (No description).
How can i solve that problem?
Please send us the stream address to support@djsoft.net we'll see what's wrong there. But if it doesn't play, I don't think there's anything can be done about it - if it worked before but stopped, it means something's changed on the stream side.
The point it's that it happened with all m3u8 files I tried, not only with one of them.
I install the new version, I tried and it worked once, but then it doesn't worked anymore.
