Radio Logger
We are experiencing a new problem with Radio Logger that we haven't seen before.  It appears to be stable and recording BUT it is not making the recordings in 1 hour files.  Instead it has created a continuous file for the past 320 hours.  HUGE filesize too !
At first we thought it was because we had selected AAC format, so we tried it again today in MP3 format and the results were the same - current file being 4 hours or more long.
The optional settings are set to 1 hour files.
Can you please help ?
Thanks, Jamie C.
Do you use the latest version?
You may also try reinstalling it to a different folder - maybe some settings file got corrupted...
i am also having the same issue too. it was recording the files in one hour parts then all of a sudden it records for 10 plus hrs before i realize and manually stop it.
Action Radio 95.1 said:
is there any update on the radio logger issue? where its not stopping after the schedule recording.
Not yet. We're still unable to reproduce the issue.
Please post here a screenshot of RadioLogger settings window.
please attachment for screen shot
Even with all settings exactly as yours (except different sound card), problem is not confirmed.
Please check if you're using the latest version - 2.2.1.140.
Also, if possible, please try recording with another sound card.
another suggestion is it possible to enter into the schedule the actual show name to be recorded. and the logger automatically record and save the show as that name entered in the scheduler. Instead of the default dates and time.
