radioboss using wine
Hey djsoft
when i installed radioboss before using wine
no sound came out of radioboss at all
and when i tried to select which soundcard i wanted to use
it said i had no soundcard using radioboss on wine on my mac laptop
thanks
RadioBOSS requires DirectSound to operate. Did you install DirectSound (or DirectX) support for Wine?
I don't know... We'll check how RB works on Wine and an instruction will be posted to help you set it up.
Hey Djsoft
when using radioboss on wine to talk live
it does not allow you to talk live using a mic on radioboss using wine
so what could be wrong then
thanks
RadioBOSS wasn't extensively tested under Wine. You can try switching the microphone driver to another option - maybe it will work.
Hey Djsoft
everytime i use radioboss using wine
it saids i have no audio drivers installed
thanks
Please wait until we publish a guide on how to setup RadioBOSS using Wine. It should happen really soon.
I did a quock look at it... First of all we have to make some adjustments in RB to make it work under Wine (eg a problem with File Explorer and some others). I'll let you know when RadioBOSS is ready to be used under Wine without issues.
