RadioCaster and SSL conection
Alfredo Correa
Hi, How do I connect RadioCaster with a server that uses Icecast2 with SSL certificate? Because if I use https://yourdomaim.com: xxx does not work and does not connect.
Icecast only uses SSL for listener connections. You should configure the stream as usual. Do not prepend server address with https:// or http://, you only need to specify yourdomaim.com
