RadioLogger accessibility issues
DJ Graco
Just as I started a thread about accessibility issues in RadioCaster, I'm now creating a thread about radioLogger. I've also noticed some accessibility issues with this program.
As of version 4.1.0.0:
1. The version information window is the same as in RadioCaster. Of course, I know the version can be read from the title bar, but there's also other information there, such as the license, copyright, etc. Links are visible from under the tab key.
2. The "Check for updates" window is the same as with RadioCaster.
3. The product key is correctly accessible, just like in the latest version of RadioCaster, so that's great, thank you!
4. Probably the biggest issue, the scheduler window, is completely unavailable with NVDA; I can't do anything with the arrow keys or the tab key.
That's it. If I find anything else, I'll update.
Greetings
Graco
