villanosuy
The RB gimme this error:
FireDAC][Phys][SQLite]-314. Cannot load vendor library [sqlite3.dll or libdb_sql51.dll]. No se puede encontrar el módulo especificado
Hint: check it is in the PATH or application EXE directories, and has x86 bitness.
How I can fix it? I use w7 64 bits and until the upgrade I have never problems.
Thanks fot the help
Thanks fot the help
