Random song from library
Oldies
Hi,
I have a playlist which is mostly made of tracklists in order to play random songs. It's easier than generating a regular playlist. But the downside is that I end up having to make separate playlists which are used only by the master playlist.
Would it be possible to play a song directly from the library, using the same criteria used to generate playlists? As an exmaple, instead of this:
(tracklist) 70s.m3u8 (random)
would it be possible to add something like this:
song [genre: 70] [tags: disco]
or something to that effect?
Thanks!
