Kevin H Member Dec 9, 2022 #1 When I click on the relay start or relay stop, a new tab opens. Can I turn this off so that no new tab is opened? I want to have it built into my panel.
D djsoft Well-known member Staff member Dec 9, 2022 #3 Kevin H said: When I click on the relay start or relay stop, a new tab opens. Can I turn this off so that no new tab is opened? Click to expand... It should not open any tabs. Can you please make a screenshot to illustrate the problem?
Kevin H Member Dec 9, 2022 #4 When I issue the open api command in the browser, it displays (ok) in a new tab. Can it be done without that tab with ok? So without response
D djsoft Well-known member Staff member Dec 10, 2022 #5 Kevin H said: When I issue the open api command in the browser, it displays (ok) in a new tab. Can it be done without that tab with ok? So without response Click to expand... RadioBOSS doesn't open such windows. How do you run the command?
