SOLVED
I mapped entire partition (D:\) from Live PC.
Dmitriy
Can you give me an ideea about making playlists remotely through RadioBOSS as production tool?
If I map a folder from Live PC in Production PC it is not enough. The path will be wrong.
I need this until you will find a solution for the future version
(that's my request).
By the way!
I do not need only the libraries (becouse in that way it works very well) but I also need to drag and drop tracks in playlist from browser; tracks which are not in libraries.
Thanks!
Dmitriy
By the way!
Thanks!
