Repeat Playlist doesn't seem to work.
twinkie
Hi, for somereason 'repeat playlist' doesn't seem to work.
I have a long playlist in the program interface 'Playlist 1'
I have 'repeat playlist' selected. but once the playlist has completed, the player stops (doesn't repeat)
My station is in test mode atm, not live....so i have the same playlist repeat all day (a long 4-5 hour playlist)
Once the playlist goes through everything, its supposed to repeat, because I have the repeat button pressed next to the player. However, the playlist stops
nevermind! figured it out! 'Stop after this track' was also selected.
IMO, pressing 'stop after this track' should automatically unselect 'repeat playlist'
JMO :)
Not necessarily, you may want to keep the Repeat Playlist on, and use Stop after this track manually, and expect that when you turn it off, the Repeat Playlist mode will stay.
