Rotating songs from same artist from different folders.
EdOwen
First off, I have an older version of Radio Boss. 6.0.6.2
I want to insert hourly a song by an artist, featuring a hit one hour, and then other album cuts. Totally random each hour which one it triggers. I have the songs divided into two folders. Call them 'hits' and 'others'. Is there any way under this version of the software to set a percentage of time it goes to one folder or the other? I looked at using priorities, but I don't see an option to use 'folders' as a plus or minus.
Is this possible under my version or an upgrade?
I know I can do this by using multiple playlist generation during the day, but to cause a good mix I'd have to do several playlists which I'd rather avoid.
Thanks for any guidance on any way to make this happen.
Ed
I think I solved this using ratings. I'd read the instructions 20 times and it didn't sink in. I'm fixing it now and believe the problem will be relieved.
