davidbcn1970
Currently, if you set the fade out time to stop, that setting only works when you press the stop control button, but if a stop command is programmed, the fade out time is different and very short (1 or 2 seconds). .
The stations that use time signals or time tocs (a function that would also be welcome in Radioboss, since now it has to be programmed with events not without some difficulty), usually create a stop with fade out at the end of the hour (minute 59 and 53 seconds), so that while the audio that is playing disappears, the time signals enter.
So far the only elegant way I have found to do it is with a multiple event, in which there is a fadeout 5000 command and a clearplaylist command.
It would be much better if Radioboss had the function of generating time signals (every 30 minutes or every hour), instead of doing it by events. Since this way the time signals would be mixed in the main output, and work independently of the playlist, and could even work with the events disabled, for live broadcast.
The stop command should be able to take the fade out time of the stop control or be able to assign its own fade out time in the settings.
