Scarlett 4i4 ASIO outputs
Mrshades
I am trying to run two instances of RB and setting the 1st instance to Focusrite ASIO outputs 1 and 2 and the 2nd instance to ASIO outputs 3 and 4. I can not get both to work at the same time.
If I'm using only one of the programs I can get either outputs 1/2 or 3/4 to work on it, if I open the 2nd RB install the 3/4 outputs don't work but the 1/2 do work.
Any thoughts on what I can do? I have been forced to use a 2nd DAC to work around this for the time being.
Some ASIO devices do not allow simultaneous use by multiple software programs. Try checking the sound card's driver settings maybe something's there to control it.
