Schedule editor
southernfm
Entering the time in the schedule editor, you can't easily see the AM/PM part
resolution is 1680x1050
It appears that you have increased the "Secondary windows fonts" option, and the time does not fit in the box. You can try decreasing the font or using a narrower typeface. We'll see if auto-resizing of the box can be implemented there.
Ah! Yes we have. Thanks.
