I'd like to request some features which I think would be beneficial:
Schedule Options
1) Currently if the playlist is stopped and a schedule runs to generate a playlist, the playlist will start playing. Can an option be implemented so that the playlist is generated but the 'state' remains the same? Or simply to not Play if the playlist is Stopped ? So something like "Do not effect Playing status" or "Do not Play if playlist is stopped" (Similar to 'Do not action this event when playlist is stopped').
2) An option for an event to trigger when RadioBOSS is started - Could be used to ensure event(s) is always fired when RadioBOSS starts, such as setting volume, loading a 'initial' playlist etc.
Silence Detector
1) Currently we only have the option to load a specific playlist. Can an option be implemented to execute a program? I know a playlist can be created to do this (run a program) but what if you don't want the existing playlist to be effected and simply run program outside of RadioBOSS? (In our situation, this would be a script which just sends an alert via email + txt).
Playlists
1) The ability to switch/control Playlist 'tabs' via the API.
2) The ability to target Playlist 'tabs' via a event/schedule/playlist generation.
Schedule Options
Silence Detector
Playlists
