Bug reports show that it freezes when it checks tracks in the playlist (you have the "Show nonexistent files" option enabled). Why it hangs - it's a question, we'll investigate it. It could be hard drive failure, or antivirus (or virus) that intercepts file operations.
A workaround would be to disable the nonexistent file check: menu Playlist->Extra->uncheck Show nonexistent files.
