Scheduler ( late )
Hi , i have some network streams schedule to be broadcast a live dj show at 10 am , but sometimes the dj will be late, so the regular play list takes over and play, is there a way for the software to grab the stream when he is ready ?
Are you required to add the lenght of the program in the url line #3600 , #7200 etc ?
(relaystart http://test.dyndns.org:4555 #3600 )
The relaystart command doesn't support the length modifier. It's only used when you play network streams.
Use the relaystop command in a separate event to end relaying.
Relay works, but its playing over the ads scheduler , the ads files are playing on time , but the network stream is being heard.
You can set the "Priority over the relay" option for the events that should play while the relay is playing.
It the show is 3 hours , do i create a stop schedule for each hour?
