James Totton
Greetings!
I am having a few problems setting an accurate mix point in the new track tool. I need your help
Am I correct in saying the position of the MIX point depends on where the END point is?
Even though I set the MIX point at the right place according to my ears, when I played two songs back to back, the mix point (or the place where the next song starts) was several seconds earlier than I had set it -and the transition between the songs was not good.
I was able to fix the issue by moving the END point manually to the very end of the track. However, do I have to do this with all my thousands of songs? Appreciate your help.
It may also be that I am confused about the difference between MIX and END.
Kind regards from Singapore.
