show groups
ormston
in the same way that showfilters has check boxes across the top of the scheduler for the weekdays, it would be useful to have groups also available as check boxes, possibly just underneath/above
You can minimize the group to hide all events in it - double click on the group header in the list to expand/collapse it.
ormston
that actually is SO helpful, thanks, i did not know this, this has changed the way i work, very good, i am not sure if its in the manual, but i hadn't seen this, impressed with this, thanks dimitri
