Radio-Albena
HI all,
Siche I updatetd from 6.3.3.0 version to 7.2.2.0 I have some strange problems.
I have generated several playlists an the weher picked random by a event every hour.
The lists have about 20-30 songs inside, all working, I have checked this, but Radioboss just skipps some of them, in the log file he shows them as normally playedd but he did not play them?? Very strange.
No I found something stange in de sound sertings Radioboss ah setting to play 44KhZ in the wondow soundsettings stood 48kHz I changed this now , but i do not know if thiss could be the problem.
second issue was the teaser, this one worked perfect in version 6.3.3.0
Now I had the same event for a teaser, openings sweeper, transition, end sweeper.
Now he skipped also the teaser a I found out that he needs too look further as the 3 preview tracks I want to have, enough tracks where in the list, but still he did not play it, as I set the max tracks to look ahead to 8, the teaser worked again, but not the next 3 tracks , he just picked some from the list. I saw there is no option to set he should pick next 3 tracks just trackcount 3. Is this option hidden sonwhere else or removed?
Now i hear 2 songs playing at the same time , this is very weard
