I have used Radio boss for quite some time,, still learning as I go.
I prefer to manually import music tracks into the playlist window, instead of using the playlist generator.
I have my music files sorted according to my own parameters.
When I add the entire music folder into the playlist window, the files are loaded in alphabetical order by group/performer, not in the sequence / order I have them sorted inside the folder (the order i want them to play in the playlist window).
Is there a way to have the files inside the added folder load in the precise / exact order as stored, instead of loading the folder contents alphabetically?
This would be the greatest improvement to an already fine software program!
